Home > Maintenance & Mods (L405) > Strange water leak.
supershuttle
Strange water leak.
I have tried the search and can’t find anything specific to my problem, which is. If I top the coolant up to the max a slight water leak takes place until the level reaches min then it stops. I have been quoted £140 to diagnose plus Shocked whatever parts are needed plus Shocked whatever it costs to fit them. Anyone got any suggestions? Geoff
Post #629570 24th Apr 2022 7:23am
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
Stating the obvious (!) but sounds like the expansion tank itself has a leak??
Post #629571 24th Apr 2022 7:46am
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
I agree with JCW
However, can you clarify if it leaks as soon as you fill it, or only when the car is running? How quickly does the level drip… and can you see wet under the car? If so, where abouts? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #629574 24th Apr 2022 8:14am
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Geoff, just make sure you don’t have a leak on the rear heater matrix feed pipe, it runs down the car drivers side beneath the plastic sill cover under the car and is prone to leaking at the joint just behind the jacking point at the rear. If you look under the car with you head just in front of the rear wheel and look up you can see them. I would also change the expansion tank cap as the first port of call, this is the cheapest place to start, other than that its a look around every where checking for any pink stains.
Post #629580 24th Apr 2022 9:01am
