Home > Technical (L322) > Trans failsafe prog error |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 969 |
I admire your optimism, but I think it unlikely that it’s an electrical fault. Your transmission should drive in its failsafe gear (and reverse) without any electrical input whatsoever. There are so many mechanical and hydraulic issues with the GM 5L40-E transmission in the Range Rover that it would be pure speculation to guess which particular one has befallen your car. Hopefully the codes will give some clues, if you can let us know what they are.
13th Apr 2022 5:22pm |
TimperleyRR Member Since: 13 Aug 2016 Location: Manchester Posts: 50 |
Thanks Phil, got to be optimistic when you go touring in the family RR!
14th Apr 2022 3:48pm |
I am still waiting for my garage to read the codes but my own IIDTool is returning only unknown errors from the potentially relevent modules. These would be:
23rd Apr 2022 11:38am |
Like you say, unfortunately those codes aren’t very enlightening .
24th Apr 2022 3:15pm |
Hi Phil,
24th Apr 2022 6:47pm |
Update:
26th Apr 2022 8:05pm |
rhory Member Since: 15 Jun 2018 Location: larkhall Posts: 1 |
Hi, meant to post this ages ago, Autel AP200, code reader, about £60, clears transfail on the fly, mate has been driving his vogue for 3 years using it, with no problems… after being told gear monitor fault meant a replacement box. Just leave connected in obd and to phone, select diagnostics, after downloading your one free vehicle software land rover/jaguar..select model diagnose next select AT, once set up, if you get transfail click read codes note codes and click clear codes, full gear box again, any other time you can just clear codes on the fly, that’s it…beats a new box any day👍 |
12th Jun 2024 9:56am |
Just thought should update this. Problem turned out to be when the car went from 3rd to 4th gear. Took it down to have then entire gear box replaced with a specialist recommended by this site in Liverpool. Car drove fine after that till we sold it and replaced it with a V8 supercharged. So unfortnately it was a mechanical issue with that notoriously fraglie automatic transmission after all. |
12th Jun 2024 5:51pm |
