Home > Technical (L322) > ACC and braking
DeeJay
South Africa 2011 Range Rover Vogue SE TDV8 Fuji White
ACC and braking
Noticed recently that there is a noise coming from behind the drivers footwell area when the ACC brakes. It sounds like something taking in air where it shouldn't be, like a pipe with flowing water taking in air - a big ole slurping sound.
This doesn't happen when braking without the ACC (ie manual), and full braking power is always available even with the noise present.
I could start investigating if I understand the components that would actuate braking when the ACC is switched on? 2011 Vogue SE 4.4 TDV8
Post #629383 22nd Apr 2022 11:05am
GraemeS
The ABS pump runs to operate the brakes in the same way that traction control works, opening and closing valves in the ABS modulator as required to apply appropriate braking force.
Post #629404 22nd Apr 2022 1:00pm
