Home > eBay & Bargain Spots > Anybody tried these?
Page 3 of 3 <123
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Hiya Dave it was very easy to split the light unit. I used a heat gun instead of going down the oven route. GSXRdave advised me to use a heat gun, it worked very well indeed. Just remove the 6 retaining clips and heat the gap between the lens and unit and use a flathead screwdriver to gently prise the len's away. I heated all around the gap of the unit first. Don't be afraid, it won't melt, i used the gun on a slow speed at number 8 heat. Then just unscrew the inner surround from the lens and remove. 20-30 minutes max to remove lens and replace. I didn't bother to reseal mine as it was just a crappy light to experiment on. Hope this helps?
Post #628835 17th Apr 2022 1:11am
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Argh, that’s frustrating!
I suppose its some positive news you found out that soon from rearranging the tape… It would have really annoyed if you sprayed them up and then found the chrome had lifted! Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #629397 22nd Apr 2022 12:38pm
Page 3 of 3 <123
