Home > Maintenance & Mods (L322) > Brake Pipe Cover on Near Side
dhallworth
There’s a cover that runs along the inside of the body on the underside of the near side of the car that covers the brake pipes as they run front to rear. I’ve circled it in this picture.
Cover:
The fixings for it are a black plastic fixing with a hex on the top of them, like the fixing in the middle of this plate.
The parts book shows the part number for the fixings to be this which looks nothing like the one above and nothing like the ones I removed from the car.
It’s just the bit in red I need:
Mine aren’t gripping when I’m putting them back on so I’m looking to replace them. Does anyone know if there’s a part number for the fixing or if I’ll need to buy the plate assembly above and remove them?
Thanks,
Post #629273 20th Apr 2022 10:34pm
Piet
Netherlands 2008 Range Rover Autobiography 4.2 SC V8 Lucerne Green
Hi David,
I make them myself, is that a option?
Just meld the hex key in.
Piet
Post #629284 21st Apr 2022 8:13am
dhallworth
Thanks Piet.
I was thinking about that last night but as I need to order a few bits anyway thought it would save me some time. Smile
Will have a look into it this evening.
Post #629286 21st Apr 2022 8:36am
dhallworth
Do you happen to know what size drill you use in the end of them where they go into the thread on the car, Piet? 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #629288 21st Apr 2022 9:01am
Piet
Ha…..yes I do David.
Drill I used is 4 mm hex key is 6 mm.
Dont make the hex to hot, just enough to meld in.
Post #629303 21st Apr 2022 11:52am
dhallworth
Thanks Piet.
I've got some nylon rod that I'll stick in the lathe this evening Smile
Post #629305 21st Apr 2022 11:55am
Piet
RR’s keep you busy Laughing
Post #629310 21st Apr 2022 1:33pm
dhallworth
Job done Smile
Thanks for the measurements, Piet!
Post #629341 21st Apr 2022 8:54pm
Piet
Thumbs Up Thumbs Up Your welkom
Post #629348 22nd Apr 2022 5:30am
