Home > Maintenance & Mods (L322) > Droning noise when turning right and slowing down
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi Guys trying to diagnose this issue loud droning noise when I turn right into a roundabout and its apparent when slowing the truck down. Its Not the tyres as never had this before with 22s on the truck plus I have just changed all 4 tyres to see if I had a bad tyre causing it etc. NOT wheel bearing had them checked. Any ideas much appreciated. Still get the noise when I put the truck into N when going into a right turn or slowing down so can't be gearbox related.
Cheers
J Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #628783 16th Apr 2022 12:34pm
DrRob
Could be CV joint or prop shaft maybe? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #628795 16th Apr 2022 4:02pm
Happydaze
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
My bet is that it'll prove to be a wheel bearing, despite them having been checked out. I have a ffrr but haven't ventured into much of it but based on my wife's Shogun, which seems to eat front wheel bearings, I've found bearings can be noisy and pass genuine mot's, and although not sure, I suspect the ffrr design isn't much different to the Shogun, which is very different to a setup on a typical rwd car.
Obviously I could be wrong as there's lots of other components that could explain your symptoms! Good luck in the hunt!
Chris
Post #628802 16th Apr 2022 6:18pm
jaysta10k
Yeah I hope your right to be honest I’m still convinced it could be a wheel bearing might just bite the bullet and the front 2 replaced. I hope it’s not transfer case related then again it would make the noise on turning left and right if was surely.
Cheers
Previous Cars
BMW M3 Carbon Black
Post #628815 16th Apr 2022 8:11pm
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
I had a Disco 4 making similar noises. Wheels off, proper thorough check. Wheels on, pulling and pushing, no play whatsoever.
A few hundred miles later the OSF wheel bearing screeched for a few seconds, just as I was pulling in the drive. Wheel bearing shot. Sometimes you just can’t check!
Post #628820 16th Apr 2022 8:55pm
dingg1
Had a 330 bmw, was sure it was the diff whining, wheel bearing in the end was the culprit, another vote for bearing here
Post #628823 16th Apr 2022 9:09pm
Merchy
Had a slight droning noise when turning one way........
Found a road with lots of long bends that could be taken at 30 to 40 mph, when steering to the left, the right bearing was 'loading up', got the droning noise ( barely audible ), but not when steering to the right.
Jacked the car up for an inspection, tried a laser temp gun after a run, there were no other indications that the bearing was going, and I could not find ANY other faults, my 'Engineers' gut instinct was to change the bearing, changed and cured, once off I could 'Feel' the bearing was not right and on the way out. A pain to change but not too expensive.
Post #628857 17th Apr 2022 9:01am
