![]() | Home > Maintenance & Mods (L322) > Please Help! - 4.4TDV8 Intermittent Starting Problems |
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 194 ![]() ![]() ![]() |
I'm at a loss and need some advice to troubleshoot why my 4.4TDV8 is struggling to start. Once started it runs fine. Here's the symptoms:
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
ignore me Cheers, Greg
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 ![]() ![]() ![]() |
I have had the same issue and I think I am at the tail end of it.
ffrr14 - thank you for this 🙏
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2641 ![]() ![]() |
I found an earth strap near the bottom of the right side rear (looking forwards) of the radiator, found when R&R'ing the fan shroud. |
So, I did the GraemeS mod yesterday and added a high-current relay into the circuit between the engine compartment fuse box and the starter motor. It has started without hesitation every time since and in as many different scenarios as I could try. It's only been 24 hours (but quite a lot of starts) so I need to keep an eye on this for longer to be certain, but I am quietly confident that this might well have done the trick. I will try and do a proper write up with some photos and a how-to that might get wiki-fied but, in the short-term and for this thread, here's what I did:
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1365 ![]() ![]() |
Its a common fix for starting issues on tvr chimaera and griffiths which seem to suffer from the same issues especially when hot... |
Yes, I can vouch for a hot engine seemingly making it worse. I often found that the vehicle would start when cold, even with a slightly lower battery voltage. I could drive for an hour so assumed my battery would be at full charge for its state of health, but then get a no start! It was infuriating! Anyway, no non-start issues so far and hope it continues that way long-term![/quote] Andy
Can remember more than once filling up the chimaera with fuel and being unable to restart the damn thing, having to go back to the garage cashier and get a push out of the way of the pump until it had cooled off a bit, then discovered the relay mod.
