Home > In Car Electronics (L405) > looking for an amp replacement mine got under water-found
karba78
France 2013 Range Rover Autobiography 5.0 V8 Baltic Blue
Hello
got water under footwell, with a leak in roof pipe. my seats units and my amplifier are dead
found the seat units but not the amplifier
would someone know which part number i should be looking for my 2013 L405 autobiography with meridian system
thank's all 2013 L405 V8 5.0 Aspirated Autobiography
gone 2005 LR3 V8 4.4 HSE
1999 TD5 Defender
Post #627094 27th Mar 2022 1:36pm
Which meridian system do you have? Small, medium or large sir?
Post #627120 28th Mar 2022 12:48am
karba78
Hello
sorry for the delay Craig, did not know there was 3 versions...
i had the large one, got the part number
thks much
SVR MERIDIAN AUDIO Range Rover Amplifier CK52-19C164-DN 2013 L405 V8 5.0 Aspirated Autobiography
1999 TD5 Defender
Post #628395 11th Apr 2022 7:46pm
I think I have one but I’d need to check the part numbers tomorrow sir…
Post #628403 11th Apr 2022 9:04pm
karba78
found one, thank's much Craig 2013 L405 V8 5.0 Aspirated Autobiography
1999 TD5 Defender
Post #628692 14th Apr 2022 9:27pm
Oh ok… We’ll, if that doesn’t work out then I definitely have one the same sir… 👍
Post #628697 15th Apr 2022 12:31am
manxaircrest
Isle Of Man 2013 Range Rover Vogue SE SDV8 Nara Bronze
Believe I'm looking for same amp due to the same reason... do you still have and if so part number etc ? Very best Brian
Post #645443 12th Oct 2022 2:39pm
