![]() | Home > Technical (L322) > Resting battery voltage |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
This is interesting, because mine is the same. Brand new top of the range battery, IID tool reads 12.1-12.3.
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 351 ![]() ![]() ![]() |
Just took it back to Halfords they checked it and it was reading 12.3 after a 20min run asked to check one on the shelf it was showing 12.7, I told the car via the iid I had replaced the battery but it didn’t give me any options to choose the type I had fitted and on further investigation via the iid under type of battery it says unknown is this meant to be the case 2012 Range Rover Westminster 4.4 TDV8
An agm battery should be charged at a low rate, imo about 36 hours and then it should read about 13V or so.
RiverBlanche Member Since: 20 Apr 2021 Location: Retford'ish Posts: 97 ![]() ![]() |
Hi,
checked this morning via the tow socket 12.4v 2012 Range Rover Westminster 4.4 TDV8
Can you tell an idiot (that’s me), how you check via the tow socket please? |
ive got a comfort charger i use via the tow socket and can use a mulitmeter with this to check voltage, if you have the new 13 pin tow socket you can do it by just touching the correct pins this is also true of the 2 7 pin sockets the grey one for a caravan has a permanent live but if you only have a black 7 pin you cant check the voltage 2012 Range Rover Westminster 4.4 TDV8
Mine is about that after a new AGM earlier in the year. 2012 TDV8 Vogue (L322) |
