Home > In Car Electronics (L322) > Range rover blank audio screen
Jamie
Ireland 2011 Range Rover Vogue SE 4.4 V8 Nara Bronze
Hi all . I have a a blank screen and flashing on off button on my 2011 vogue se. The screen comes on for a few seconds and then restarts itself continuously. I have checked the fibre optic circuit and the red beam is present going in and out of all the modules in the loop . I have a continuous beam as far as the cd changer and then it's a broken beam (stays on for a few seconds then restarts ) after the cd changer onto the module under the seat and all the rear modules . Would any of you know where to look next please . Thank you
Post #627905 6th Apr 2022 9:59am
RBFFRR
United Kingdom 2011 Range Rover Vogue TDV8 Fuji White
Did you ever get a anywhere with this? Experiencing something similar. Cheers
Post #639485 13th Aug 2022 1:59pm
sounds like a dodgy bluetooth unit...have a look in our wiki for a solution. ... - .- -.
Post #639487 13th Aug 2022 2:21pm
RBFFRR
Thanks, I had seen this wiki and sounds like a simple fix, but not sure it's quite the symptoms I'm getting. I'm away at the moment (with the car) so I'll take a proper look when back at home. Thumbs Up
Post #639489 13th Aug 2022 2:52pm
3.6dave
United Kingdom 2003 Range Rover Vogue Td6 Buckingham Blue
Hi Jamie, I've just had the same issue with my 09 3.6 Tdv8. The screen went black, on/off button flashing and no sat nav, radio tv or phone. I did a bit of research and figured the MOST optical system seemed a likely candidate. It sends an optical signal ( red light to you and me! ) through a fibre optic cable that feeds through all the modules. If there is a break it shuts all of them down. The signal starts out in the Integrated head unit behind the dash and then passes through the Cd changer to the display and then on to the portable audio module below the seat and then to the stack in the rear left hand quarter panel space. For an easy way to check for the break I removed the passenger seat and unplugged the fibre optic connection and checked for the red light! Luckily it was lit on one side so the problem was further back in the vehicle. I then went to the Bluetooth module ( easiest to get at ) in the boot and checked there, no red light! By disconnecting each module in turn and looking for the red light i eventually got to the tv module whgh had red light in but nothing out to the next one. I checked power and earth to the module and they were ok so bought a fibre optic repair/ test bypass connector from e bay. When I plugged it into the optical connector which went into the tv module everything worked except the TV. Bought a second hand tv receiver from E bay and plugged it in and all's well! Everything back to normal. Hope this helps. Dave.
Post #646340 23rd Oct 2022 11:30pm
pcourtney
but please do not look at the red light more than a second, it is "laser light", and you should be using Laser Optic safe glasses when doing that sort of thing with any Fibre Optics !
NB I know it is low power, but your eyes still need protection.
Post #646350 24th Oct 2022 9:12am
there's no need to 'look' at the fibre optic light, you just shine it onto some dark material.. ... - .- -.
Post #646353 24th Oct 2022 10:23am
pcourtney
that's correct Stan, but so many people find it irrestible to look directly into it - and that is why I bothered to mention this more as a warning to others - hope you don't mind
Post #646355 24th Oct 2022 10:48am
