![]() | Home > Technical (L322) > ZF8speed frustration |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Its not stuck in 'sport' mode by any chance? does switching it to sport mode make any difference?
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
If you have an IID you can reset the 'learned' shift behaviours
It's definitely not stuck in sport mode. AFAIK the GAP reset function removes all the adaptation values for wear and age that influence the smoothness of the changes rather than the programming of the change vs load/speed etc? If anybody has done this I'd like to hear but I'm not tempted on a box that changes smoothly. 2012 TDV8 Vogue (L322) |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2566 ![]() ![]() ![]() |
A person in this part of the world is offering remapping for the 8-speed to go hand in hand with a 4.4 TDV8 remap. I'm very interested but would need to test drive a vehicle that has been done. I too would like the gearbox to make better use of the engine's torque but I wouldn't want to loose the way that mine ambles along tracks at around 1000 rpm at 40-60 kph. |
Mine ambles along just fine on the flat. 2012 TDV8 Vogue (L322) |
@Jaygee.
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 372 ![]() ![]() ![]() |
S alluded to above the gearbox learns the drivers habits. If you regularly use the paddles to change gear they do tend to hold the gears longer as if in sport mode.
I’ve only just started using the paddles after putting up with it since September. I’d have thought also that using the paddles this way would teach the box to follow my override rather than the other way round? 2012 TDV8 Vogue (L322) |
@Jaygee. I'm the same as you. It did it from the very start when I bought in it 2017. I started to use the paddles as required when I noticed it holding on to gears and thought it would learn my style too. Nothing changed! |
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 ![]() |
I found the 8speed was very irritating when going down steep hills. Up hills it would down shift (usually not irritating enough to intervene with paddles) but going down steep hills it really |
Mine holds the revs going down steep hills as well and I think it's a normal feature with these ZF boxes as my Audi Allroad did it as well but I don't mind it as much as the uphill rev holding. 2012 TDV8 Vogue (L322) |
It’s the brake assist cutting in |
