Home > Technical (L322) > Intermittent DPF sensor electrical fault at ECM
Smitch
United Kingdom 2012 Range Rover Westminster TDV8 Stornoway Grey
I have a recurring issue where the voltage for the DPF pressure sensor drops causing incorrect soot values and restricted performance.
I know the fault lies either direct on the ECM connection or the immediate wiring in the plug as if I lift the harness or press the connectors the voltage shoots up to normal, when driving if the nose is pointing downhill or I’m going over bumps it will drop and eventually throw RP
Also I parked the car on the drive and got the voltage to flatline and checked from the sensor up to the ecm, there was no change until fiddling in the ecm area when it came back to life.
Live data when loose leading to RP (see drops)
Live data after pushing in ECM connectors (working perfect)
I’m at my wits end … I’ve removed the plug and checked for damaged pins and all is ok and there’s no obvious bulging or splits. I’ve fully reseated the plug and ensured it’s connected it’s stabilised for now but I don’t have much confidence.
Does anyone know what wire(s) or pin(s) relates directly to the dpf pressure sensor as it would help me pinpoint the issue further and hopefully get a final fix?
Post #627789 5th Apr 2022 1:38pm
Smitch
I’ve dug through the WM and found a wiring diagram,
Based on some bench remapping tutorials I think I have sussed out the pin layout (left to right and bottom to top based on pin size) so assuming the 6 large pins are 1-6 and the first small pin is 7 I think that the sensors pin out is as follows:
Does this sound right?
Post #627802 5th Apr 2022 3:46pm
