Home > Maintenance & Mods (L322) > Rear wiper and lower tail gate latch not catching
Slow progress
Hi all,
A quick question how do you get the rear wiper into a position to change it? And also what are the recommended blades for rear and front?
Lastly the lower tail gate isn’t latching straightaway, it looks like the catches aren’t fully retracting, is there a fix for this?
Many thanks,
D L322 TD6 2003
Epsom Green- the dogs car which has worked it’s way into being the family car 😮
Post #627794 5th Apr 2022 1:49pm
Baltic Blue
It’s in the W.M. if you need more detail.
Mike
Little tip,
Spread out an old towel on the roof to lay the spoiler on whist you work on the wiper. 👍 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #627795 5th Apr 2022 2:02pm
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
To just change the blade switch ignition on to run then switch rear wiper on, when arm is in mid position switch ignition off you can then lift arm to change blade, when its done ignition back on rear wiper off ignition off.
Post #627853 5th Apr 2022 10:41pm
JayGee
Lift the tailgate when the wiper is mid position and it will stop - may take a few attempts to catch it. 2012 TDV8 Vogue (L322)
Post #627867 6th Apr 2022 5:46am
kds2
Lifting tail gate didnt stop it on the 04 or the 08 I have now, its a switch it off job.
Post #627986 6th Apr 2022 7:03pm
