Home > Technical (L322) > Knocking struts or CV-joints? |
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 274 |
Did you say you’ve changed the front drop links? I changed the rear shocks and then the prop centre bearing before doing the drop links |
3rd Apr 2022 2:54pm |
Ian928 Member Since: 16 Aug 2016 Location: Kristiansund Posts: 78 |
Yes, I did change the drop links. It did nothing for this knocking sound. Also, I get no knocking when pulling the steering wheel from side to side when driving. 2006 Supercharged |
3rd Apr 2022 4:04pm |
Update: changed struts, and the knocking was still there. Last week we changed the Britpart drilled and slotted brake discs to Brembo parts, and the knocking is gone. My theory is that the holes for the small bolts were too large, and the disc were able to slide slightly bak and forth between the Wheel and hub. 2006 Supercharged |
31st Jan 2023 12:25pm |
Triumph72 Member Since: 11 Apr 2018 Location: Argyll Posts: 39 |
Glad your sorted, always nice when someone updates the solution to a problem.
31st Jan 2023 4:00pm |
