![]() | Home > Maintenance & Mods (L322) > Oil Cooler Change - When it started so well |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 903 ![]() ![]() ![]() |
If you don't have the right torx socket......mole grips?
Ansi Member Since: 07 Nov 2014 Location: Muenchwilen TG Posts: 146 ![]() ![]() ![]() |
Yeap, that's what I would do; two nuts and may be a bit of heat with a propane torch!? |
davethomas83 Member Since: 12 Dec 2015 Location: Gloucester Posts: 30 ![]() ![]() ![]() |
Cheers Gents - think I might be a little scared to get heat in there due to the pipes, put 2 nuts now that’s a sensible idea!
So far, I at least have the nuts that fit so good start.
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Two nuts locked is the way to go, for the future forget WD40 it's rubbish for anything other than cleaning, use plus gas for freeing off fastenings, available by the gallon on Amazon with a pump spray, much better. BMW i3 Electric Car
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
A slightly smaller long reach socket gently hammered into place? 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
A 9mm 16 sided long reach socket knocks on nicely from experience… Do at least 2 of these a month and many of them are stuck!
Thanks for all the suggestions guys - had a quick look yesterday at the 2 nut option, but muggins over here has caused a bit of damage to the tread trying to get it out with pliers. Only tried for a couple of mins as the pull of the pub won out the day.
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2562 ![]() ![]() ![]() |
LR023027 appears to be the stud. |
Success !!
So with one source of potential oil leaks resolved - still have far too much oil coming out to consider it just residual.
After watching some YouTube videos ( i couldnt find this detailed on any engine diagram i cold find ), i think this must be mabe an engine mount point, as nobody has anything in this.
