Home > Technical (L405) > Dreaded Restricted performance. |
Peter d Member Since: 13 Jan 2017 Location: Virginia Water Surrey Posts: 12 |
Well I too recently had the dreaded restricted performance warning message on my MY17 4.4 TDV8 but this only happened when I gave it some welley. It would usually clear once the engine was switched off for a few minutes although this may be coincidence.
3rd Apr 2022 4:36pm |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 |
This may help - especially the link Stan posts.
4th Apr 2022 7:46am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3778 |
Mine started doing this after a service (was OK before) no faults showing on IDTool but “clear all faults” seems to work. So does stopping for a bit of lunch. Any ideas? Geoff |
8th Apr 2022 10:24am |
madasmad Member Since: 22 Mar 2020 Location: Cheshire Posts: 83 |
My MY16 was like this and I would clear the faults as I was driving use the iid app. It turned out to be a software issue and an update sorted it. No problem since 2019 Autobiography SDV8 Byron blue/black - current
19th Apr 2022 3:45am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2469 |
The connector for the pressure sensor fails for which a repair kit is available comprising of a new connector and short length of wires. |
19th Apr 2022 8:09am |
