Home > Technical (L322) > Front windshield wiper park position switch |
ksskaret Member Since: 27 Oct 2013 Location: Tromsų Posts: 73 |
My front wipers are going bananas on my MY2010 and after using my Faultmate following fault code showed up:
2nd Jul 2014 7:52am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35326 |
when you say 'wipers go bananas' , what do you mean? ... - .- -.
2nd Jul 2014 9:24am |
It parks in various places, when doing ONE-swipe it goes 5-15 times before it stops. It seems that there are nothing physical hindering the movement. Range Rover TdV8 Autobiography MY2010
2nd Jul 2014 9:34am |
i did a quick google and it seems that defenders have this problem and its due to a faulty 'park switch'..not sure whether the FF has one of these but its worth investigating...
2nd Jul 2014 9:40am |
Thanks Stan,
2nd Jul 2014 11:25am |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 968 |
I don't know if the design changed for later models but there's a photo of the park switch from a 2003 model in this post : http://www.fullfatrr.com/forum/post122708.html
2nd Jul 2014 11:32am |
Hi Phil,
2nd Jul 2014 11:40am |
Westminster_Bri Member Since: 17 Jun 2019 Location: Gloucestershire Posts: 31 |
I've just had the exact same issue on my 2012 Westy... It IS the motor park sensor. No way to fix so you will need a new motor... if you leave it, aside from the frustration it will eventually give up the ghost and stop altogether...
30th Mar 2022 12:37pm |
jellmers Member Since: 30 Mar 2022 Location: Plymouth Posts: 5 |
Thanks.....
30th Mar 2022 12:44pm |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 |
Any model year will work from my experience. eBay is your friend. Bish.
30th Mar 2022 5:16pm |
V8rumbler Member Since: 07 Mar 2018 Location: Devon Posts: 113 |
I have the same problem - what is involved with swapping out the motor ? 2007 Vogue TDV8 in Stornoway Grey with Jet interior NOW SOLD 2011 (12MY) 5.0 S/C AUTOBIOGRAPHY ipanemaSand with Jet Interior |
13th Apr 2022 8:33am |
Best of luck finding one! My saga (despite what I wrote earlier) has continued! After 3 weeks of faultless operation, my second hand motor has started doing the same thing! I guess you could say I have some very bad luck!
13th Apr 2022 9:11am |
Thanks for that - funnily enough plymouth is my local dealer . I will contact them .
13th Apr 2022 9:31am |
Thanks - also do you have the part number please -?. I need the 2011 one . Also is it the whole setup with linkage or is the motor available separately 2007 Vogue TDV8 in Stornoway Grey with Jet interior NOW SOLD 2011 (12MY) 5.0 S/C AUTOBIOGRAPHY ipanemaSand with Jet Interior |
13th Apr 2022 9:45am |
