Home > Maintenance & Mods (L322) > Rear disc removal
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Rear disc removal
Wanted to change rear disc today…but once I had wheel off, brake calliper off, I was unable to rotate the disc so I could align the adjustment hole to the spiked spigot to back off the old shoes.
What am I missing? I could only move the disc a few degrees in either direction before it stopped
Post #627031 26th Mar 2022 4:58pm
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
Select neutral & of course ensure the parking brake is released Thumbs Up
Post #627032 26th Mar 2022 5:15pm
Rambles
Did that. Came to a stop. Selected neutral. Ensured park brake not selected. Switched off ignition
Post #627033 26th Mar 2022 5:34pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Try keeping the engine running when in neutral, when you turn off the car it goes into the park?
Post #627034 26th Mar 2022 5:39pm
Do you not have to jack both rear wheels up?
Post #627035 26th Mar 2022 5:42pm
JCW
I seem to recall mine re-applied the EPB when leaving in neutral and turning the ignition off, so I think I left the ignition on whilst lining up the holes.
Edit Tinman beat me to it!!
Post #627036 26th Mar 2022 5:42pm
Rambles
Could be EPB could be automatically applied when turning off ignition. Difficult to say really as the rotary gear selector withdraws flush and the lights go out.
I could try leaving the ignition on …….but no mention in workshop manual about ignition being left on
And you tube shows everyone effortlessly spinning the disc
I didn’t even reach the point where the spigot gets adjusted to back off the shoes
Adjust backwards says the manual
Does that mean push the spokes upwards ?
Post #627037 26th Mar 2022 5:53pm
Tdtj
Scotland 2016 Range Rover Autobiography SDV8 Santorini Black
Once engine is shut down automatically goes into park 2016 4.4 diesel
Post #627042 26th Mar 2022 6:33pm
kevinp
I agree with nicedayforit as long as the handbrake is off.
Post #627054 26th Mar 2022 9:15pm
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Make sure you have both rear wheels off the ground, this will then let you turn the wheels via the rear diff if all the brakes are free and H/brake released! If you have three wheels on the ground your going to really struggle due the 4x4 system.
Sorry if I’m stating the obvious but an easy one to trip people up with constant 4 wheel drive.
As for the adjuster, it depends which way it was flitted last time. Try turning it, if it locks the disc go the other way. Thumbs Up
Post #627082 27th Mar 2022 10:00am
Rambles
I can jack up at the back using the central mount / jacking point
And then with wheels still on see if there is any variation of engine on / ignition on to work on the wheels
If I can only work on the discs with engine on…then off to an Indy it will go
Would be curious if that was the requirement
Post #627150 28th Mar 2022 3:10pm
When l last did mine l jacked up both rear wheels and to get sufficient leverage on the disc l wanted to rotate l used a breaker bar between two of the wheel studs. Worked without engine or ignition on, indeed l can’t think of any reason why it wouldn’t.
Post #627160 28th Mar 2022 5:26pm
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
Same here, jacked the back end completely and both rear wheels will turn. Car in neutral and EPB off Thumbs Up
Post #627162 28th Mar 2022 6:01pm
diesel Dave
Definitely don’t need ignition on to do this Thumbs Up
Post #627166 28th Mar 2022 6:59pm
diesel Dave
Post #627167 28th Mar 2022 7:00pm
