Hi, I have a 2012 AB with the design kit, I fitted a Westfalia tow bar subframe which is not the one shown on the eBay picture
the one you have shown I believe is just the swan neck? because of cost.
The correct fitting is much heavier and fits where the bumper and towing points are, which have to be removed.
When using the correct Westfalia system with the design kit, you have to remove the cover/splitter 4 plastic turn screws to attach the receiver, for the two types of hitch, Farmers or swan neck also the electrics sit within the bumper.
Don't forget you will have to tell the car that you have towing electrics ie: 7 pins or 13 pins otherwise the rear sensors will not cancel when reverse is selected.
My advice is to look for a good clean s/hand one.
Alex
