Home > Technical (L322) > 4.4 TDV8 Vibration/Rumble - RPM related |
hotpotatojr Member Since: 05 Oct 2021 Location: Blackpool Posts: 71 |
Thanks yep that makes sense (about the MAF).
21st Mar 2022 9:06pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2489 |
Under faults, select advanced. Mine has test failed, pending and confirmed with a green tick. IIRC confirmed wasn't set ex factory. |
22nd Mar 2022 2:29am |
thanks - wasn't aware of that!
23rd Mar 2022 10:08pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1217 |
This is a complete stab in the dark but do a you tube search for, pa6-gf30 turbo boost valve. |
23rd Mar 2022 11:22pm |
Hi Kevin, thanks....tested the boost valve today and its working fine...the light blue line refers but it's commanded 'late' at around 3k. The green line relates to the measured position which isn't long after.
23rd Mar 2022 11:35pm |
It's complicated stuff mate but there are three of them units in the system and I have no idea what they do to be honest. I've just sold a couple to a member on here.
24th Mar 2022 12:14am |
Yes mate, I bypassed the valve and connected the permanent vacuum to the turbine shut off valve and IIDTool shows the secondary turbo permanently active, so all hoses are fine.
24th Mar 2022 7:43am |
It sounds like you know your way around things. Sorry I couldn't help. Hope you sort it . |
24th Mar 2022 7:54am |
no problem thanks for the input - it's a quiet post this one and as far as I can tell there's only me and Rambles with this issue so obviously not a common one! Trawling the internet hasn't helped either as it's such a specific setup on these engines. |
24th Mar 2022 8:25am |
Have you checked the harmonic balancer/front pulley and the belts for unusual behaviour as the revs go up and down through the rumble zone? |
24th Mar 2022 9:49am |
Thanks Graeme I couldn't see anything obviously wrong with the harmonic balancer/front pulley and the belts (the Mrs must be sick of revving the car for me )
24th Mar 2022 5:40pm |
It seems as though you've found the cause!
24th Mar 2022 7:34pm |
Interesting to see that your fan connecting nut is a dull colour. I'm investigating a dull humming noise and was wondering if it could be coming from the fan. But my nut is clean and bright in colour so I'm suspecting it has already been changed.
24th Mar 2022 10:19pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 807 |
Interesting. My previous Indy had replaced those same pipes for the air con which run across the top of the shroud for the fan just before my problem started.
25th Mar 2022 6:09am |
