Home > Maintenance & Mods (L405) > Wind noise through drivers window. |
RRVSE-2 Member Since: 06 Jun 2015 Location: Kent Posts: 41 |
Are you sure its the window, l had a similar noise and it turned out to be a loose a pillar trim. Keith
19th Mar 2022 5:17pm |
Edgey808 Member Since: 17 Apr 2016 Location: U.K. Posts: 48 |
I have the very same issue, but seemed to have fixed it by bending the top frame in towards the roof. Sounds harsh but it works….
19th Mar 2022 7:51pm |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
I had this when I first bought my L405 (used). It was just the door seal rubber drying out. I ragged on a bit of Autoglym Bumper and Trim Gel, problem solved. Kev
19th Mar 2022 10:31pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
Open the door and with the window down place your knee on the top of the door panel, your hands on the top of the frame and bend it inwards... Its remarkably easy to bend it inwards |
19th Mar 2022 11:38pm |
154JON Member Since: 31 Mar 2019 Location: Essex Posts: 129 |
Thanks |
21st Mar 2022 8:10pm |
Perfect! |
21st Mar 2022 9:54pm |
