Home > Technical (L322) > Restricted Performance fault TDV8 4.4
Page 4 of 4 <1234
Jod1rrs
United Kingdom 2014 Range Rover Autobiography SDV8 Firenze Red
It’s the 4.4 v8
Post #626468 19th Mar 2022 8:43am
GraemeS
The hoses are easy enough to change. Slide all 4 further onto the donut to be clear of the manifold connection, remove the donut, swap the hoses then refit the donut. I used silicone spray on the donut to make the new silicone hoses slide more easily.
You might want to allow quite some time to cleanout the donut while its off.
Post #626482 19th Mar 2022 11:13am
Jod1rrs
Thanks will give it a go 😊
Post #626492 19th Mar 2022 3:24pm
Jod1rrs
Just another one for you, had is plugged into scanner today while driving and ran a data stream
CATTEMP11 was constantly in the 200s while
CATTEMP21 was in the 400s and fluctuating more
Should there’s be reading more or less the same?
CATTEMP11 is bank 1 sensor 1
CATTEMP21 is bank 2 sensor 1
Thanks
Post #626545 20th Mar 2022 4:00pm
Page 4 of 4 <1234
