Home > Technical (L322) > CV boot
Neil E
2019 Range Rover 2.0 PHEV Mariana Black
CV boot
Hi All,
I know this is a `how long is a piece of string` question but how long are CV boots designed to last?
I had a garage fit one to the O/S back in Oct approx 8,000 miles ago. This has now split and chucked grease all inside the wheel arch.
Is it worth complaining to garage to see if it can be changed under manufactures warranty or is it just one of those things that can happen, if say a stone has hit it??
Neil MY21 P400e AB
MY10 3.6 TD V8 Autobiography
55 Vogue se
Post #62595 4th May 2011 11:06am
dan_uk_1984
Stones could hit it all day long and it wont fail...
I would expect a 12 months parts and labour warranty on anything fitted by a garage, unless it was a cash job or something similar where you have very little to fall back on.
It was probable that the CV was fitted incorrectly, nipped etc. Or a cheap universal one was used?
Post #62602 4th May 2011 12:09pm
Fox
Sounds right, on our fleet vehicles they nearly always go over 100k miles / working life of the vehicle to 10 years old!
Post #62604 4th May 2011 12:11pm
Pauld
United Kingdom 2004 Range Rover Vogue Td6 Zermatt Silver
Mine lasted over 120,000 (sold before failing)
One side had a very small split, not enough to fail a MOT or leak
Post #62625 4th May 2011 2:52pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
yes unless its been hit with something then 8k is way tto early for it to fail.
Is it a clean split which looks to be a join? reason i ask you can get CV boots which you glue, easier labour but a bodge. 2004 black Vogue TD6
Post #62643 4th May 2011 6:32pm
liverpoolphil
United Kingdom 2003 Range Rover HSE Td6 Tonga Green
I am having an ongoing minor issue with mine after replacing OS drive shaft recently. Problem is mine keeps popping off its fittings, has done it on both ends now. The mechanic has now 'refitted' it twice but its a pain in the arse having to keep an eye on it, and a further pain in the arse having to drop it at the garage then pick it up again Evil or Very Mad
Post #62701 5th May 2011 8:58am
Sorry to HIJACK your thread but I'm doing my breaks at themmoment and my drivers side, outer cv inner joint has come off. It's been previously fix/bodged with a jubalie clip. Now can I reseal it with a clip or do I need to do anything else? Should I inject grease into the boot?
Post #62745 5th May 2011 1:13pm
