![]() | Home > Technical (L322) > L322 4.4 TDV8 - DPF not regenerating |
Engine oil temperature and not coolant temperature may be what it's waiting for which will take longer. Not sure why you told it a new DPF was fitted as this could mess it up. AFAIK soot level is measure by the pressure differential across the DPF so if it thinks the DPF is new it will not require much soot load to assume it's very full. 2012 TDV8 Vogue (L322) |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
I can only think that you could try and get a HIGH pressure smoke test done because I suspect it will finally prove to be an air leak on the intake somewhere.
One further point, keep an eye on the oil dilution figure, it will soon reach the limit of 7 with all those failed regen attempts.
An intake air leak would indeed cause a rapid soot build-up but I can't see how it would prevent normal or forced regenerations. A sticky EGR valve will prevent regeneration if it can't close but this would throw a fault code. 2012 TDV8 Vogue (L322) |
Neanderthal Member Since: 25 Dec 2021 Location: Highlands Posts: 10 ![]() ![]() |
Thanks both.
I think the investigation should be directed at the engine temperature fault the diagnostic is reporting. 2012 TDV8 Vogue (L322) |
As Jaygee says.
Hi JayGee,
I know people do forced regens on the GAP IID tool successfully but no idea on the iCarsoft? I've no idea what other temperature inputs are required for regeneration and it may include EGT? 2012 TDV8 Vogue (L322) |
https://www.fullfatrr.com/forum/topic60984...+using+iid
Just a thought….
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2665 ![]() ![]() |
Beat me to it Mike |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1268 ![]() ![]() |
Actually during my monitoring, the normal day to day Active Regeneration, I have recently seen it occur at less than 1/4 tank (in-between red and 1/4) but, I have never seen an Amber on mine, maybe an Amber does need a minimum 1/4 tank as there is a lot more soot to burn off? But then mines a L405 and will have different DPF architecture and algorithm? But without doubt I never go below half a tank these days, as anything can happen! I don't think 25mins is enough though, you could be interrupting it every time if you are doing short journeys. I have also seen normal regens at oil temperatures in the 60's. So more inclined to think an Active Regen is a combination of Engine temp, soot % and engine running time and speed. Would love to get my hands on a flow chart regarding the algorithm ![]() Passive Regen starts at DPF temps of 250 Celsius which is above 63mph for me, you could plan to do a 1-2 hour 70 mph motorway run that will eat away at your soot% but being on amber it could very soon turn to Red on your way to a motorway. Maybe someone on this forum lives close to you with a Gap tool, that can force it for you? It can also scan and see your sensors are functioning, oil dilution level etc etc. 2018 SE SDV8 4.4 Byron Blue |
Thanks again all, lots to work with. I'm taking it to a garage this evening that has a Gucci tool. It may be that I need to invest in one of these Gap tools for myself.
