Home > Maintenance & Mods (L322) > Parked for couple of month, handbrake stuck on
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
As above, the TD6 has been parked for a couple of months (didn’t know it was going to be that long) and now, after a new battery, it won’t actually drive forward or back, even with the handbrake off. It squats slightly, creaks loads then nothing. Big Cry
Is it a simple case of keep trying? Or could I damage something? (Worried about the flimsy gearbox on these)
It’s parked one side tight against a house, so at present I couldn’t even get to one side to manually free anything up
Any pointers or advice greatly appreciated guys Big Cry
Post #625893 10th Mar 2022 12:43pm
Try gently driving back and forth, it my free off. Thumbs Up Don’t worry about the creaking. Very Happy
Post #625894 10th Mar 2022 12:52pm
mpirie
You could try banging the rear drum to try and shock the shoes away from the drum.
Maybe a hammer on the wheel nuts?
Just make sure you don't damage anything.
Mike
Post #625895 10th Mar 2022 12:53pm
Sandyt
Not sure what the set up is for the handbrake is it a handle with cables ? if so then try putting it in gear with the footbrake applied 1500 to 2000 revs then release footbrake do a few times forwards and reverse it worked for my p38 which had a similar problem also if it is cables on handle if you can get underneath spray the cable carriers with wd good luck
Post #625898 10th Mar 2022 1:21pm
dhallworth
When you're trying to rock it back and forth, use low range too. Lots more torque without the revs Smile 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #625903 10th Mar 2022 1:32pm
mrblonde
Cheers guys, free'd her up eventually with the forward/reverse technique, just didnt like the creaking but all good now.
dhallworth - I've got a confession, its never been in low range since I've owned it (12 years), was told if its not been in low range for a while it could be more hassle than its worth, and if you are going to try low range to do it at home on the driveway just in case. So i havent been brave enough (or needed it to be honest)
Post #625928 11th Mar 2022 1:48am
Sandyt
Glad you are sorted I cycle mine every week into low range same with the handbrake once a week also all the heater controls
Post #625929 11th Mar 2022 4:48am
