Home > Technical (L322) > front suspension lowers |
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 168 |
Hi, I had a similar problem where the rear was lowering. Can’t remember if I got the same fault code but the rear offside sensor was not working so I changed it and it solved the problem. From what I can remember the whole of the rear of the car lowered because one sensor was not working, might be an idea to check the sensor to see if the wires are broken or not. |
9th Mar 2022 7:38am |
Just remembered to add that once I started the car the rear end did rise up to normal height and only lowered when parked up overnight. |
9th Mar 2022 7:40am |
marcel911 Member Since: 07 Mar 2022 Location: kalmthout Posts: 2 |
It takes a while for the car to lower( 2days). I think it's an air valve that fails but I don't know which. |
9th Mar 2022 10:31am |
