Home > Technical (L405) > Fumes in cabin when warm & stopped/going slowly - SDV8 |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1189 |
Have you checked the intercooler in the `V` check for oil in the expansion cooling tank? It`s a known fault? |
7th Mar 2022 7:36pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2653 |
It’s the vent pipe for fbh, it vents below the gear shifter, very common . Mine is the same , very bad smell when it’s cold and no wind to blow it away . |
7th Mar 2022 7:44pm |
thomsonaj Member Since: 03 Mar 2022 Location: Scotland Posts: 5 |
Thanks both - appreciate the replies.
7th Mar 2022 8:26pm |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2576 |
My money is on the oil cooler |
7th Mar 2022 8:27pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
are you sure it is diesel fumes and not burning oil fumes?
8th Mar 2022 8:04am |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 899 |
There are a couple of O rings that get brittle on the turbo feed pipes that can allow oil to leak out onto the bell housing.
8th Mar 2022 12:51pm |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
I agree, either oil cooler or o rings. Have a look in the V to see if you can see oil. Kev
8th Mar 2022 2:44pm |
Thanks very much all - took her into the garage this morning so will see what they come back with. Such a wealth of knowledge on here, want to reiterate thanks for suggestions so far.
8th Mar 2022 5:03pm |
ivo_markov Member Since: 21 Mar 2022 Location: Sofia Posts: 12 |
Got this done last week, 600Euro job at the main dealer. It was hot oil smell, tried changing cabin filter at first too.
21st Mar 2022 6:12pm |
Closing the loop on this one - smell was a fractured ARB header tank (the one that's a dark colour on the nearside front of the engine bay, makes it impossible to see fluid volume...) which was leaking fluid onto the manifold when under pressure.
4th Apr 2022 10:02am |
JakeyKev Member Since: 07 Jul 2023 Location: Scotland Posts: 5 |
Hi ThomsonAJ,
7th Jul 2023 8:27am |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 675 |
JakeyKev,
7th Jul 2023 9:04am |
Ah cool, thanks MarianaWestminster.
7th Jul 2023 10:14am |
