![]() | Home > Maintenance & Mods (L322) > L322 Suspension ECU |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2572 ![]() ![]() ![]() |
The suspension ecu holds the calibrations for the height sensors so one from another vehicle will need calibration.
Old Barty Member Since: 05 Sep 2021 Location: Suffolk Posts: 21 ![]() ![]() ![]() |
Hi Graeme, Thanks for the response --- The history is that I have had the 2 front sensors replaced with OEM units as the ones on the car were aftermarket units--this was due to getting the message 'Suspension Fault 30MPH ' The fault codes pointed to the 2 front sensors at that time. It has been OK for a couple of months but I knew it was going to fault again as I have been driving with the 4x4 display on the screen and I have noticed that the 2 red markers have started dancing up and down randomly and the more often than not it goes into fault mode . I have not had the codes read this time,yet, but I figured that as both the front sensors were new, I could reasonably rule them out |
Have you tried refitting the suspension ecu connectors? The ecu is under the left end of the facia and the front sensor wires are in the long grey connector. There are 4 connectors in total, 1 small and the other 2 appearing identical shape but have different keying. As your earlier problems were overcome with new sensors then it doesn't seem likely that faulty wiring/connectors is the cause but access to the suspension ecu is easy so worth R&R'ing the connector. |
Morning Graeme -- Thanks again. No, I have not yet touched a thing. Good Idea though as it appears a reasonably quick and easy thing to so.---- I'll give it a go today, weather & wife permitting and see wheat I find or what happens.. |
Unnecessary quote removed
