Home > Technical (L322) > Window closing
Slow progress
Window closing
Hi All,
A new day a new issue! When trying to shut the front passenger side window it’ll move up to about 2” from closing and then halt, rocking back and forth on the window switch eventually gets it to close (mm by mm!) is this likely to be regulator failure? L322 TD6 2003
Epsom Green- the dogs car which has worked it’s way into being the family car 😮
Post #625546 6th Mar 2022 7:22pm
tj196443
United Kingdom 2010 Range Rover Vogue TDV8 Zermatt Silver
That just sounds like it needs a reset, get the window to the top of the frame and keep your finger on the switch as of to keep on raising the window for a few seconds.
Post #625555 6th Mar 2022 8:15pm
