Home > Maintenance & Mods (L322) > Megaflush
Page 2 of 3 <123>
DrRob
You won't regret it. Have him do the transfer box too. Full house!
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #623865 16th Feb 2022 8:37am
JayGee
You could also consider what the manufacturer of the gearbox recommends which is a not to flush but simply a drain of the fluid and filter change. It gets enough of the fluid out to extend the life of the gearbox and you may get it done sooner. Ditto get the transfer box and diff's done at the same time. 2012 TDV8 Vogue (L322)
Post #623874 16th Feb 2022 9:18am
Chrali
Bodsy did my megaflush, diffs and transfer box fluids today on my 2012 L322 with 52k miles, luckily the weather was quite pleasant in Norfolk today.
The transmission fluid was well used, the rear diff was clean and most likely been changed before, but the front diff was less clean and had some small metal particles. Do I need to be unduly concerned about that?
I only had a couple of codes for drivers door central locking, but perhaps that's related to a couple of cases where it couldn't lock as I hadn't shut it properly.
As for how it drives, well its definitely smoother and it gives me piece of mind. I was also happy to see no oil on the underbody panels, so doesn't look like I'm due for oil cooler woes for awhile (i hope). It was nice and dry underneath, with just some surface corrosion.
Ian himself was professional and polite as I've read everywhere else, he certainly put up with my wittering about past cars Laughing , but I did leave him to get on with it for the most part.
Bodsy gets a thumbs up from me. Encourage alternative fuels, use all the petrol!
2012 Range Rover Vogue 4.4 TDV8
2006 Mercedes GL420 CDI
2006 Porsche Cayenne Turbo S
2006 Jeep Commander 3.0 CDI with GDE HOT Tune
1997 Nissan Patrol 4.2 GRSE
1995 Vauxhall Monterey Diamond 3.2 v6
1994 Range Rover 4.2 LSE Beluga Black, Softdash, Brooklands Body Kit - Loved it!
1993 Range Rover 4.2 LSE ended up converted to 300tdi
Post #625285 4th Mar 2022 12:53am
DrRob
Glad to hear it Thumbs Up
Bodsy. The Legend Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #625299 4th Mar 2022 8:59am
colalowe
United Kingdom 2012 Range Rover Autobiography TDV8 Buckingham Blue
How can I get in touch with Bodsy? I have a 2012 L322 and would like the diffs gearbox and transfer box all doing. Does he travel to Lancashire? I’m not sure where he is based?
Post #625350 4th Mar 2022 8:08pm
DrRob
He's mobile so comes to you
07770638023 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #625374 4th Mar 2022 10:38pm
colalowe
Perfect, thanks šŸ‘
Post #625987 12th Mar 2022 9:29am
biggles3124
England 2008 Range Rover Vogue TDV8 Tonga Green
The Great Bodsy
I had my 08 Vogue TDV8 3.6 given the full Bodsy treament in January.
That included
Gearbox flush and reset
Remove EGRs. fit cover plates and amend electronics so no fault lights showing
Drain and Refill both Diffs
Stage 1 Tune giving 40 more bhp and near 100 ft/ibs torque
Reset engine electrics to latest Range Rover specification
and he wouldnt even accept tea or coffee when working until late in afternoon with head-light
Car drives even better now.
Does anybody know where I can get under car cleaned and protected in Hampshire area please ?
Post #625996 12th Mar 2022 11:47am
DrRob
Yep! Glenrands do Lanoguard treatment. About to do mine. Tell Ross I sent you... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #626000 12th Mar 2022 12:10pm
biggles3124
Hi Rob
Thanks for reply
Rough idea of cost please?
Hope you are well
Regards
Steve
Post #626002 12th Mar 2022 12:18pm
DrRob
Hi
Not asked myself yet Rolling with laughter
Ross is your man to ask Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #626007 12th Mar 2022 12:59pm
Sandyt
I change the gearbox every 30k with new filter etc and even having done that when Bodsy did mine the oil was not great they started saying that the gearboxes were sealed for life and keep on changing the recommendations - mine drives like new now it has settled down after the mega flush and it is on nearly 220k
Post #626076 13th Mar 2022 3:11pm
JayGee
How was the oil 'not great' - did you have it tested? AFAIK ZF have not said their gearboxes are sealed for life and this was only JLR. 2012 TDV8 Vogue (L322)
Post #626141 14th Mar 2022 12:18pm
Mikey
ZF state the service interval is every 50-75k miles or 7 years
Sooner, if you do regular off roading, towing or high speed driving Thumbs Up
Post #626177 14th Mar 2022 9:46pm
TJH
So, what's the ball-park cost of a megaflush?
Post #626335 16th Mar 2022 8:59pm
Page 2 of 3 <123>
