Home > General > Panic beginning to set in
supershuttle
markdotreed wrote:
Tempted Geoff?
https://www.autotrader.co.uk/car-details/2...amp;page=1
Now thats a very nice car. Geoff
Post #625124 1st Mar 2022 9:47pm
Mikey
Vogue wrote:
She hasn’t been in the sea at anytime has she ? Boat launching or a splash through salt water ? I have seen corrosion like this before on a friends RR Sport used for launching a jet ski
Didn't have a towbar
Other than back and forward to work, and the occasional continental jaunts, it was a relatively pampered car
Thankfully, it's rhe only one we've seen like that, but we have seen corrosion build up on quite a few cars now...
Post #625274 3rd Mar 2022 9:23pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
That's Not good Shocked
Post #625306 4th Mar 2022 10:47am
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
“Thankfully, it's the only one we've seen like that, but we have seen corrosion build up on quite a few cars now...”
Mikey, are there specific areas you’re seeing this, aside the rear subframe mounts you’ve already highlighted? would be good to know where to check & hopefully catch before it becomes an issue Thumbs Up
I had hoped to leave corrosion problems behind when moving from my L322 to an all aluminium bodied L405 Rolling Eyes
Post #625320 4th Mar 2022 1:46pm
Mikey
As chance would have it, we had a 2015 in today for a service...
White powder = bad Neutral
Post #625652 7th Mar 2022 9:37pm
dhallworth
Shocked That’s not a good sign! 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #625653 7th Mar 2022 9:55pm
Mikey
Another yesterday. 63 reg. Not good... Neutral
Post #649424 29th Nov 2022 8:20am
fisha
Quote:
Being aluminium, I don't know how to even begin repairing that. And the floor pan is bonded together, not welded.
Alu can be welded, but it's much more finnicky than steel.
Your comment about bonding had me thinking though. I wonder if a few could be bonded in place rather than welded. Imagine that you cut out the affected area, and a new piece which was moulded to cup around the larger area got bonded into place ?
I know getting a new piece would be a pain, but it'd be an easier process overall. V8 or else ...
Post #649433 29th Nov 2022 10:25am
Kot
I tried many years (25 years lol) to stick weld aluminium, with aluminium rods, it's like welding butter lol without any warning if it gets just slightly too hot it collapses into a molten mess. It can be done nowadays with TIG/MIG or plasma but never tried that lol.
Some interesting info here, not a project for DIY
https://www.uti.edu/blog/welding/aluminum-welding 2018 SE SDV8 4.4 Byron Blue
Post #649434 29th Nov 2022 10:58am
dhallworth
Was that a car that had spent most of its life in Scotland, Mikey?
I keep looking at 405’s to replace my SC at the moment but this puts me off as it’s a much more specialised repair then the steel 322’s if they need welding.
Post #649436 29th Nov 2022 11:10am
Bill
Nope not good at all, the rest of the car just rusted into thin air Laughing Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #649441 29th Nov 2022 1:00pm
Mikey
David.
I dont know the history of the car, its the first time we've seen it in
Post #649513 30th Nov 2022 9:08am
Kot
It looks like JLR depend on both surfaces having a protective film to prevent Galvanic action, even the fastenings are coated.
I would have thought from Mike's photo's, JLR would have fitted some sort of insulated gasket/spacer etc with insulated sleeve bolts during the build. Relying on a few microns of protective paint etc is totally not good Engineering practice. Just 1 scratch during installation and the barrier has gone!
I found below files in the WSM which may be of interest for anyone who goes down a weld repair it shows weld procedure and grades of Aluminium used (filler wire). The approved MIG welder uses Direct Current, (DC) and does not produce High Frequency, (HF), at start up, (initial arc).
Corrosion prevention
https://www.fullfatrr.com/gallery/albums/u...ENTION.pdf
Body Construction and welding techniques
https://www.fullfatrr.com/gallery/albums/u...UCTION.pdf 2018 SE SDV8 4.4 Byron Blue
Post #649542 30th Nov 2022 2:29pm
