![]() | Home > Maintenance & Mods (L322) > How To: L322 Full LED Interior/Exterior Upgrade - Full Guide |
Barkballz Member Since: 21 Feb 2022 Location: South West Posts: 1 ![]() ![]() |
Really nice write up - will be doing this for my self with your inspiration so thank you.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
Have now added the guides for all lights! 2015 Range Rover Autobiography 4.4 SDV8 |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Links to the items are under each step heading. 2015 Range Rover Autobiography 4.4 SDV8 |
G3BML Member Since: 22 Jul 2021 Location: Glasgow Posts: 98 ![]() ![]() ![]() |
A bit off topic, but where did you get the pedals from? Much nicer than the standard rubber/plastic ones! |
£12 delivered. 2015 Range Rover Autobiography 4.4 SDV8 Last edited by garyRR on 16th Aug 2022 9:40pm. Edited 1 time in total |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
Good write up mate. I've been doing mine however the main interior light has caused me a few issues as it won't sit back in place properly any more.
Drop out the unit again and align the tabs on the unit facing toward the front of the car. Once these are aligned and the front of the unit is seated flush, pivot the unit into place (back of unit with metal tabs). Check the metal tabs are located correctly and then press firmly until the light unit goes back into place. Don't remove then try and push the light unit vertically back into place. The front facing section must be located first then pivot the rest of the unit in. In the photo, the front section is clearly not located correctly. Also make sure the metal tabs align with the little slots in the trim before pressing firmly. 2015 Range Rover Autobiography 4.4 SDV8 |
Cheers mate.
Jambo Member Since: 15 Oct 2016 Location: Cumbria Posts: 20 ![]() ![]() ![]() |
Great improvement and really easy to follow steps. Thanks for producing and sharing such an in depth 'how to' |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1300 ![]() ![]() ![]() |
Just a tip for getting the mirror puddle lights out without any damage to the old light if for any reason you want to keep them.
Buie Member Since: 04 Mar 2025 Location: Detroit Posts: 4 ![]() ![]() ![]() |
You're a legend Gary. Thank you. |
