Home > General > Aircon service
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
Aircon service
Guys,
Although my aircon blows icecold, I'm thinking it could use a good service, since it's a little bit smelly. Any advice on where to go and how much to pay? Or should I just replace the microfilter? 2012 SDV8 Vogue SE
Post #62502 3rd May 2011 5:57pm
bomb it boz.... ... - .- -.
Post #62503 3rd May 2011 6:09pm
Best and cheapest thing to do is use an air conditioning "bomb" - just Google it and you'll find plenty of places selling it. You turn the car on, full heat and fan speed, recirculate on, hit the button on the "bomb", close the doors and leave it sitting in the car for about 10 minutes. Worked a treat on my E60 which was getting so smelly I thought a squad of Legionnaires was living in it! Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #62504 3rd May 2011 6:11pm
here's a halfords version, probably better ones on the market though...
http://www.halfords.com/webapp/wcs/stores/...65632#dtab ... - .- -.
Post #62505 3rd May 2011 6:14pm
hongkongphooey
Isle Of Man
That's handy to know, I just ordered a pollen filter for mine as I did a search and it said that could affect the aircon efficiency. A/C currently smells like a wet dog for 5 secs on start up Thud Think i'll be trying the bong Cool
Cheers Phooey
Post #62507 3rd May 2011 6:34pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
well you learn something every day.
My air con is smelly so i just ordered my first bomb.... Laughing 2004 black Vogue TD6
Post #62526 3rd May 2011 7:49pm
bozmandb9
I just read some bomb reviews, and some of them don't seem to last very well! Anybody have a recommendation for one which worked and lasted? 2012 SDV8 Vogue SE
Post #62532 3rd May 2011 8:07pm
Just buy 2! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #62534 3rd May 2011 8:21pm
letsavit2
The fragrance will never last and just mask the smells for a while, so i suppose its how much bacteria it kills really. 2004 black Vogue TD6
Post #62537 3rd May 2011 8:25pm
nbunney
Have a look here £19.99 Thumbs Up
http://www.atseuromaster.co.uk/retail-cust...ioning.htm
Post #62539 3rd May 2011 8:29pm
lrdaft
Scotland 2011 Range Rover Vogue TDV8 Santorini Black
Forte air con treatment seems to last for months only available through the trade though 2011 4.4tdv8 vogue black with black
2005 autobiography supercharged in Auckland blue!
2005 supercharged now sold
2011evoque now sold
2007 tdv8 vogue se gone but not forgotten
rrsport 2.7 hse gone
4.4 autobiography 2004
Post #62542 3rd May 2011 8:57pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
I used the halfords one a couple of weeks ago. It works quite well and make it smell a bit newer for a while. It's definitely neutralised the previous owner fat odour, even now after the freshened has faded.
You just leave it running in the car with the air con on full recirculate. My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #62550 3rd May 2011 9:31pm
dan_uk_1984
If you use it all the time you generally won't get mould growing on the evaporator as the constant icing up will kill the spores. The other thing it could be is a blocked drain tube allowing stagnant water to pool in the bottom of the unit.
Replacing your pollen filter should be done yearly as a minimum, your eyes are the best judge of how often it needs replacing. You can check it at the same time as your oil & water it's that easy.
Also, you may think your A/C is icy cold but it may not actually be getting down to the appropriate temperature to ice the evaporator, it may be worth a re-gas which will cost £50-£75 ish.
Dan
Post #62570 3rd May 2011 11:58pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
As an extra on my last service my dealer (Stratstone) did an air-con service for £20 which involved them ensuring the coolant was doing its job and also adding a fragrance, and they also did an injector clean for £20 aswell. So had both of them done , at £40 , it was worth it I reckon, as I did notice a drop off in exhaust gases post injector clean (I would normally do this myself via an additive liquid in the fuel tank every so often). Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #62574 4th May 2011 1:16am
