Home > Maintenance & Mods (L322) > Roof Rack Fixing Point Covers and Hex Screws
steviepee29
United Kingdom 2008 Range Rover Vogue TDV8 Santorini Black
I've just taken the roof bars off my L322 and have realised I don't have the hex screws that are originally supplied with the car (I assume to keep the threads clean) or the plastic covers.
Pictures of what I am missing below - any idea where I might be able to source both the hex screws and the covers?
 Current: 2008 Range Rover L322 TDV8, 2004 Porsche 911 996 C4S Cab, 2019 M4 Competition Cab, 2018 Mercedes E220d Estate
Post #624979 28th Feb 2022 11:47am
Merchy
Check out this thread some relevant info -
https://www.fullfatrr.com/forum/topic59438...+trim+caps
As for the screws, these are easy to find on the internet or at any good engineering supply merchant, called grub screws, amongst other names, link below for screws, plus the obvious lubricant of your choice when fitting them.
https://www.westfieldfasteners.co.uk/Bolts...nless.html
Can't find the blanking plates at the moment, but someone was selling them in different colours on ebay.
Post #624983 28th Feb 2022 12:17pm
steviepee29
thank you - ordered the screws / bolts.
just need to look for the trim caps - everything has so many potential names I find it hard to know specifically what I am searching for - but you have pointed me a very good direction - thanks! Current: 2008 Range Rover L322 TDV8, 2004 Porsche 911 996 C4S Cab, 2019 M4 Competition Cab, 2018 Mercedes E220d Estate
Post #624986 28th Feb 2022 12:51pm
Merchy
As for the trim caps, if you cannot find them you could get the complete rails from a breakers yard, as far as I know the trim caps are not sold separately, and apparently trying to fit them without removing the roof rails is very difficult, but the rails are easy to remove. Hope this helps.
Post #625008 28th Feb 2022 4:25pm
