Home > Technical (L322) > Propshaft carrier bearing
kenneally_mark
Ireland 2012 Range Rover Westminster 4.4 V8 Santorini Black
Hi All,
My L322 2012 4.4 TDV8 failed the test on a torn rubber on the Propshaft carrier bearing.
Can anybody tell me the replacement part number or give me a link to where I'd get one.
Thanks
Post #624974 28th Feb 2022 10:19am
hotpotatojr
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
Hi,
Hopefully this thread helps
https://www.fullfatrr.com/forum/topic62227.html
Chris
Post #624975 28th Feb 2022 10:28am
kenneally_mark
Thanks for the reply.
Where I'm confused is which part to get.... I'm seeing a lot of different options with part numbers etc.
I'm unsure whether the 2012 is the same as the earlier ones or not? Also if its the 30mm or 35mm one I need?
TVB500400 or T0Q000050? Or maybe a different part number
I really don't want to get underneath it and dismantle it to find that I haven't got the correct part.
I'm lost! Any advice would be great.
Thanks
Post #625056 1st Mar 2022 8:57am
hotpotatojr
P/N from my research should have been TVB500400 - this was correct for my 2011 4.4 TDV8; I'm not aware of any differences between the 2012 model.
But you will struggle to find one (I did at least) which was a reputable brand AND was the correct 30mm.
Hence me buying Febi P/N 26265 / BMW P/N 26127521855 to harvest the centre bearing.
Post #625059 1st Mar 2022 9:36am
kenneally_mark
Ahh I get you. I've found one with that part number TVB500400 so I will order that and hope and pray it works! Thanks for your help & responses.
Post #625062 1st Mar 2022 10:09am
hotpotatojr
No problem, just make sure it explicitly states 30mm internal bearing diameter - I ordered one with that part number and had to return as it was 35mm (incorrectly listed as opposed to the incorrect part number).
Post #625068 1st Mar 2022 10:29am
kenneally_mark
Part ordered and photo taken of the diameter before it was sent so fingers crossed it all goes well. Thanks for your help.
Post #625081 1st Mar 2022 1:11pm
