Home > Technical (L322) > Lower glove box illumination switch/plunger
bergxu
United States 2005 Range Rover HSE 4.4 V8 Zambezi Silver
Hi gents,
Recently discovered the lower glove box light switch on my '09 HSE was letting the light inside the glove box remain lit, and therefore draining the battery after a bit. I've ordered a new switch, just curious how to access it for replacement? It's the black switch with what seems to be the light and plunger integral to it. This is for an LHD model if that matters at all.
Thanks in advance! Cheers,
Aaron
Post #624652 24th Feb 2022 6:26pm
garyRR
See my article on LED lighting upgrade.
You might not be upgrading the lighting but you can use the photos and guide for replacing the glove box switch and light unit, as I remove it in my guide:
https://www.fullfatrr.com/forum/post624853.html#624853 2015 Range Rover Autobiography 4.4 SDV8
Post #624857 26th Feb 2022 7:44pm
bergxu
Very much appreciate that Gary! Cheers,
Aaron
Post #624872 26th Feb 2022 10:00pm
