Home > Technical (L322) > ZF6HP-26 Problems
JavaBlack
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
ZF6HP-26 Problems
Good Evening,
I have a 2007 4.2 SC with 60k miles.
There are no warning messages given. It engages forward, reverse, tiptronic gears and high and low range. Park has no effect and the car can be pushed forwards or backwards. Occasionally it will move with coaxing although not consistent, and, sometimes when selecting gears you can hear the pin ratcheting on the parking pawl guide plate.
Does this sound like a internal gearbox fault or possibly a comms error?
All idea's very gratefully received
Many Thanks.
Post #624767 25th Feb 2022 11:54pm
dhallworth
That sounds as if something has failed inside the gearbox unfortunately. Sad 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #624769 26th Feb 2022 1:32am
supershuttle
I had a very different problem with my gearbox but all I needed to do was free up and lube the linkage. It may well not fix your problem but it’s worth trying as it doesn’t cost anything. Geoff
Post #624784 26th Feb 2022 10:18am
dingg1
After one if my drive shafts became dislodged from the diff I had similar symptoms
Good luck
Post #624787 26th Feb 2022 10:33am
JavaBlack
Thanks dingg1
N/S popped out
O/S
Post #624862 26th Feb 2022 9:35pm
