Home > General (L460 2022) > LWB PHEVs |
Eirik34 Member Since: 16 Dec 2014 Location: Norway Posts: 441 |
As far as I know, the P440e and P510e have identical battery packages. The power difference in the Ingenium engine is due to tuning and/or turbo. |
25th Feb 2022 8:47pm |
aja500 Member Since: 15 Oct 2017 Location: South East Posts: 826 |
Good morning Freddy,
26th Feb 2022 8:10am |
Freddy Bear Member Since: 10 Jan 2019 Location: London Posts: 147 |
Thanks Eirik34. In that case the vehicle weights should be the same (roughly) so I wonder why you can't get a P510e LWB? Surely the extra power of the P510e would be useful in the heavier LWB?
26th Feb 2022 9:06am |
7 CDB Member Since: 18 Dec 2017 Location: Lincoln Posts: 134 |
Aja500 is exactly where I am with thoughts on the L460 - we only have one child, but 2 dogs and a load of horse kit 🤦🏻♂️
26th Feb 2022 9:18am |
kevantlin Member Since: 14 Feb 2022 Location: Lancashire Posts: 25 |
I was in the same quandary as previous posters. Ended up order a 510 over the 440.
26th Feb 2022 12:20pm |
It seems we're all having to make some kind of sacrifice!
26th Feb 2022 12:29pm |
Interesting about removing the seats. Considered doing that in my defender. However I think there are rules around removing seats and road legality/insurance etc. |
26th Feb 2022 12:40pm |
Possibly, although I've had them out of my L322 for 8 years now without issue.
26th Feb 2022 12:45pm |
The difference between the 22" 114 and the 23" 111 tyre load ratings is only 90 kg/wheel. If you need to load the P510e to its max 3450kg with a weight distribution of 2360kg on the rear axel (max rating for the approved 285/45-22 114Y tyres) and 1090kg on the front axel, and you need to run such a loaded car flat out 242 km/h on German Autobahns, then you'll not be safe with the 23" 111Y rated tyres. But a P510 loaded to 3270kg - rear axel 2180kg - will be 100% safe to drive flat out 242km/h using the 23" wheels. I.e. for normal speeds the 285/40-23 111Y rated tyres will be perfectly safe also for the P510e, but not adhering to the specs might impact insurance in the highly unlikely event that you have an accident caused by tyre damage. I also hope that it will be possible to order 23" wheels separatly. |
26th Feb 2022 4:00pm |
