Home > Maintenance & Mods (L322) > Heisitation when pulling away
Chris1573
Hi all, having now replaced both EGR valves I was hoping this would go away, however still seeing hesitation when pulling away once warm no missfire as such, just a slight dip then recover. Nothing major but wondered if anyone has had similar. L322 2007 TDV8 3.6
Post #624126 18th Feb 2022 8:37pm
JayGee
Check for leaks /split hoses on the intake hoses and also clean the MAP sensor of any soot fouling. 2012 TDV8 Vogue (L322)
Post #624148 19th Feb 2022 10:51am
Chris1573
Hi JayGee,
Hoses are fine and MAP sensors as well. Seems to only happen once warmed up and you then park for a while then start up again and pull away. L322 2007 TDV8 3.6
Post #624621 24th Feb 2022 10:48am
