Home > Maintenance & Mods (L322) > 4.2 SC Belt(s) replacement guide.
conor
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Hi team,
I've just spent the last 30 minutes browsing via search..to no avail.
I'm just wondering is anybody aware of a decent guide on how to replace the belts on my 4.2 SC ?
Also,
- Am I correct in saying I must absolutely remove the fan?
- What tools do I need to remove the fan?
Thanks a lot. (07) 2007 3.6 TDV8 L322 - 135k miles.
(05) 2006 MY Supercharged L322 - Zambezi Silver on Jet Black - 162k miles.
** Smiles per gallon - never forget **
Post #624611 24th Feb 2022 2:54am
Piet
Netherlands 2008 Range Rover Autobiography 4.2 SC V8 Lucerne Green
Hi Coner,
Its a easy job. But no need to undo the airco pipe, just bent
it out of the way a bit with care.
Look in the WM in the Wiki.
And remember to loosen the fan in the same direction as the
she is rotating.
Ohh the spanner is 36mm.
This is my diy holding tool, but if you are lucky a good hit on the
spanner with a hammer wil do the job also.
Post #624619 24th Feb 2022 10:40am
Piet
In the WM
Page 883
303-05A: Accessory Drive - 4.2L SC V8 - AJV8
Post #624620 24th Feb 2022 10:48am
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
It's an easy enough job mate. Biggest pain is the fan. So order one of these, get a 36mm spanner and the rest is history. You'll need a 3/8 ratchet piece or just the ratchet on its own to take the tension off. Replace the pullys as well while your at it. Only something around £100 for both of them
https://www.ebay.co.uk/itm/Range-Rover-Spo...635-2958-0
Cheers
Allen
Post #624636 24th Feb 2022 3:13pm
conor
Thanks guys,
Would the laser fan spanner be any good listed here? It seems cheap anyway.
https://www.halfords.ie/tools/hand-tools/s...94653.html (07) 2007 3.6 TDV8 L322 - 135k miles.
Post #624957 28th Feb 2022 1:34am
Bean19844
It works but you have very little leverage on it. Go out and get a long spanner. You'll be able to give it a good smack to the LEFT and it will come off.
Post #624958 28th Feb 2022 3:07am
