Home > Technical (L322) > Running a Cable Front to Rear of car? |
Has anyone got any tips for running a cable from the glove box to the ICE in the rear of the car?
2nd May 2011 9:16pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35126 |
yes...
2nd May 2011 9:32pm |
Cool, thanks. Does it go under the rear seats OK? I've not had the trim off there before...
2nd May 2011 9:44pm |
dont go under the back seats but to the side under the trim. ... - .- -.
2nd May 2011 9:48pm |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 |
Dan, I ran the aux in cable from the boot to the centre cubby box, basically took the wires behind the trim that hides the subwoofer, lifted the side trim for the seats out of the way, iirc, it just lifts out, then tucked them under the plastic trims for the weather seals, B pillar then in my case, tucked down under the gap where the carpet meets under the seat, but you could continue it to the kick panel trim then into the glovebox that way.
2nd May 2011 9:53pm |
I ran my harness in the OEM locations when I retrofitted the nav. If you pull up the sill trims you can get to platic nuts which hold the covers over the cable conduits. If you really want to go OEM, remove the front seat to use the conduit to the console. And in the back, the wiring runs up and under the side trim - as Scarey said.
2nd May 2011 10:08pm |
