![]() | Home > Technical (L322) > FBH |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 775 ![]() ![]() ![]() |
The FBH warms the cabin, not the engine!
DaveG3159 Member Since: 05 Apr 2021 Location: Sheffield Posts: 5 ![]() ![]() |
I’ll keep looking if it should heat the cabin up, it does fire up when its cold when the engine is running which I’ve been told is to speed up the warm up period, and if I stop it I can smell the diesel fumes, so it does work in a fashion.
hotpotatojr Member Since: 05 Oct 2021 Location: Blackpool Posts: 71 ![]() ![]() ![]() |
I have a similar issue, FBH works but doesn't heat the cabin.
It will heat both cabin and engine as it's a spur on the main coolant system but it won't do it immediately and you need to set it off well before you get in the car. Like 1/2 hour before depending on how cold it is. Also AFAIK you need to set the heating dial to higher settings 2012 TDV8 Vogue (L322) |
Hi Thanks
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 814 ![]() ![]() |
No need to play with heating dials, not in my MY11
So that's what the ticking noise is......
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 173 ![]() ![]() ![]() |
Hi, you could try and pull the fuse for the FBH and it should reset itself, if there are a number of failed attempts at running the FBH it can lock itself out. Pulling the fuse and reinserting can usually cure the issue of it not running. I’m sure if the outside temp is 16 degrees or lower is will heat the cabin but need to run for at least 20 minutes on diesel, if the temp is lower than 6 degrees it warms the engine to assist cold starting. |
RiverBlanche Member Since: 20 Apr 2021 Location: Retford'ish Posts: 97 ![]() ![]() |
Hi, other way around the FBH, as already said, is to help get the engine up to temp quicker, a by product is it can be used to warm the inside of the car as well as it is heating the coolant system. OP. try setting your TC for half hour before you want it, all locked up and go out early to listen what is happening, you should hear the FBH running like a little jet engine ![]() ![]() |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 225 ![]() ![]() ![]() |
Just a thought does it have the change over valve and is it working. |
Happy to be corrected, but after thirteen years of using a Range Rover FBH in a cold climate, here's my understanding: If the FBH is used from the remote (or from the timed climate setting), the system heats the closed loop system of the cabin to warm the cabin only. When the engine is started, the valve is opened and the warm water then helps to heat the engine. The FBH works independently of the cabin heater function and will run indpendently to assist warming the engine when ambient temps are below 5deg, but this has nothing to do with cabin heating. With the car parked-up and locked, I persist that the FBH is for cabin heating only. The older I get, the more I realise that people confuse wrinkles for wisdom ![]() |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1453 ![]() ![]() |
^ this is my understanding and also my experience with both of the Range Rovers I have had with FBH's. 2021 D350 Fifty Edition - Carpathian Grey
Pysta Member Since: 05 Sep 2021 Location: Bra Posts: 24 ![]() ![]() ![]() |
I can confirm the same, unfortunately, as I want it to work the other way around and preheat the engine ![]() |
I had always thought…
