Home > General > Advice/help needed with OBDII
Ludzy
United Kingdom 2005 Range Rover Vogue SE Supercharged Zambezi Silver
Where can I get a full list of all the fault codes for L322 RR? My OBD reader arrived over the weekend and I have afew codes come up
stored:
P0202 - Injector circuit malfunction - Cylinder 2
P32C1 - Fault definition not available
pending:
C0700 - Fault definition not available
I'm only using easyobdII software which is free. Will I need to buy a decent program to obtain fault info? Also will clearing these faults just "hide" them. 1st time I've used anything like this.
thanks Ex FFRR 4.2 Supercharged
www.thecarpetfitter.co.uk
Post #62400 2nd May 2011 4:35pm
Ludzy
Sorry for the bump Wink
But I'm gonna try to get the car booked in tomoz maybe even seen and I would like an idea of the meanings of the fault codes. If anybody does know I would be very grateful.
Cheers Ex FFRR 4.2 Supercharged
Post #62438 2nd May 2011 9:02pm
this any good ludzy..
http://www.robisonservice.com/servicedep/rover_obd2.asp ... - .- -.
Post #62440 2nd May 2011 9:15pm
Ludzy
Already looked there. Only codes beginning with P0xxx
Looked all over google but can't find anything. Didn't know if somebody had a decent obd reader software that had all the definitions in?
Cheers anyway. Ex FFRR 4.2 Supercharged
Post #62441 2nd May 2011 9:26pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Dont go looking for faults they will come to you soon enough.... Laughing If it's driving and starting fine then just reset the codes and see if they come back, the variables that triggered these may never return again. 2004 black Vogue TD6
Post #62444 2nd May 2011 9:55pm
Ludzy
But it's running abiit rough. Acceleration feels different. No misfire tho. Idle engine noise sounds different aswell. I had the "reduced engine performance" msg come up twice last week on the motorway. And last Monday the engine just cut out at them lights without warning. Started fine straight after tho. Cars been fine very since but as mentioned it does feel slightly different. I need to get it sorted aswell before we take it on holiday and i gotta get it serviced. my reader gave these codes which I was not expecting. I thought it could be the MAF or pipes but after these codes I'm stump.
Post #62446 2nd May 2011 10:12pm
pretlove
do you know any one with autodata as that will give you the codes....i have it but the pc its on has crashed at the mo if i get it working soon ill let you know what they are "RANGEISM WILL NOT BE TOLERATED"
Post #62448 2nd May 2011 10:21pm
letsavit2
Maybe different OBD software will give you the same faults but with different codes. No pro here but i have googled 3 codes in the past and all come up on first page with description, tried yours which did not. If you had reduced engine performance come up then there may well be other codes that OBD wont read, your need testbook etc.
I have sent you a PM with regards to OBD software.
Good Luck 2004 black Vogue TD6
Post #62454 2nd May 2011 11:13pm
Ludzy
Cheers all
Car booked in for Thursday to be sure. Also what kind of service would I need. The RR's just gone over 70k. No service lights indicator on so just checking.
Post #62479 3rd May 2011 11:11am
