Restricted Performance but no engine codes | |
So, I seem to get the restricted performance message upon a cold start, my IID tool is picking up the following:
L405 - Range Rover 2013
Vehicle scanned on 15-02-2022 12:49
Using IIDTool BT V4.0 B2742
ATCM-Terrain Response
U3003-62 (2F) Battery voltage - Algorithm based failure - signal compare failure
( on 15-02-2022 12:49:03 at 75109 mi )
GWM-Gateway module
B13D6-87 (2F) Battery monitoring module - B - Bus signal/message failure - missing a message
( on 09-02-2022 10:29:45 at 75103 mi )
B1403-96 (2 Dual battery fuse box - Contactor 2 - Component failure - internal failure
( on 09-02-2022 10:30:22 at 75103 mi )
None of which should cause the restricted performance message.
If I clear the codes the message will go from the dash and a rescan generally returns just this pair of errors:
Vehicle scanned on 15-02-2022 12:51
( on 15-02-2022 12:51:21 at 75109 mi )
GWM-Gateway module
( on 15-02-2022 12:51:23 at 75109 mi )
Both of which appear to be fairly harmless.
Now, if I enable all bit status flags and rescan whilst the restricted performance message is on the dash I get a whole load of tests that have not yet completed, along with this failed test:
PCM-Engine TDV8
P2031-00 (27) Exhaust gas temperature sensor circuit - bank 1, sensor 2
( on 15-02-2022 14:36:27 at 75111 mi )
- Test Failed
- Test Failed This Monitoring Cycle
- Pending
- Test Failed Since Last Clear
So, potentially a faulty EGT sensor...Can anyone confirm the location of the Bank 1 post CAT/DPF EGT sensor or even the part number?
Also, any idea why the IID tool isnt picking this up out of the box?
Cheers,
Martyn 2013 FFRR Vogue SE
