Home > Technical (L322) > 2003 TD6 Rough idle / vibration at speed |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 683 |
If you come to a standstill at the lights, what happens if you select neutral?
16th Feb 2022 7:51am |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 791 |
Faulty injector or injector loom? 1st easy check, with the engine running and tick over lumpy as you describe, remove the plug from each injector one at a time, if it gets worse replace the plug and move on, if there is no change investigate that injector. I the loom or plug is in question wiggling it might get a smooth idle temporarily. Shame you are on the other side of Oz, I have a good loom and injector here 2007 TDV8 VSE
16th Feb 2022 11:10am |
