Home > Maintenance & Mods (L322) > Front and Rear Differential Change… How?
dhallworth
Thanks Graeme,
I'm lucky enough to be working on a ramp so will put a transmission jack under it and drop it onto that. I'll be removing my hubs completely as I'm going to change the wheel bearings when I change the diff so hopefully shouldn't be too bad.
Post #623642 13th Feb 2022 11:28pm
Sandyt
One thing David be careful with the wheel bearings I did mine and am about to replace front offside hub as the bearing is moving in the case I had to do one of the rears as well - to be honest cant remember where I got the bearing though got most from Dan I also had the rear prop redressed replaced the front prop and all the driveshafts when I did mine a few years ago think I was on about 160k I also replaced both diffs they were done at my local garage think Tommy might be a member on here I will ask him
Post #623645 14th Feb 2022 4:05am
dhallworth
Thanks Sandy, that's disappointing that your bearings are moving in the hub!
Will see how we go as we progress.
Post #623655 14th Feb 2022 10:22am
Sandyt
I think David they were not original parts the garage in the village got them for me and pressed them in but
I think they got some aftermarket bits
Post #623690 14th Feb 2022 5:44pm
dhallworth
Hopefully that’s all it is! I’ve got 4 genuine LR bearings to go on here.
My 36mm socket arrived today and that combined with the impact gun made short work of removing the hub nuts.
I was expecting problems getting the shafts out of the hubs but a tap with a copper hammer saw them both removed so it looks like I’ve been pretty lucky so far!
Post #623703 14th Feb 2022 8:09pm
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Well done mate, its a lottery whether the drive shafts come out easy, sometimes they just slide out and other times they need beating out.
Good luck with the rest of the build Thumbs Up
Post #623708 14th Feb 2022 8:41pm
dhallworth
Thanks Dave Thumbs Up
Most awkward part so far has been manipulating the old diff out of the gap in the subframe. Not looking forward to getting the new one in either!
Post #623714 14th Feb 2022 10:28pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Sounds like you was pretty lucky with the shafts mate that's for sure. I've gotta do the cv joints on mine once I've done the welding but dreading the fact if they don't come loose I'm going to be on a certain creek without a paddle
Allen
Post #623727 15th Feb 2022 2:32am
dhallworth
Once I got the hub nut off I was bricking it after what I'd read... Not gonna lie, I did breath a sigh of relief when they both came out.
Going to spend some time this week cleaning things up and giving bits and pieces a lick of paint whilst it's stripped Smile
It's much cleaner under there from a rust perspective then I expected it to be so might as well try and help it stay that way. Although I've done a mega amount of work to this car, I kinda can't help but think I've got lucky with a starting point.
Post #623761 15th Feb 2022 11:48am
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
By intermediate drive shaft bearings….
Do you mean the CV joints on the front half shafts ?
Post #623777 15th Feb 2022 1:08pm
dhallworth
No, there's a housing that bolts to the side of the engine with a separate bearing and oil seal on it to support the middle of the longer half shaft.
That's the bearing I call the intermediate one, I think Land Rover call it a thrust bearing.
It's inside this housing that bolts to the side of the block.
https://www.ebay.co.uk/itm/193920445146?ch...RSEALw_wcB
Post #623779 15th Feb 2022 1:21pm
Rambles
Got it.
This is the support bearing for the “rear” prop shaft that comes in 2 pieces, and runs from the transfer box to the rear differential…. And the central bearing support is where the 2 pieces of the rear prop shaft meet. It was an advisory item on my last MOT
https://www.advancedfactors.co.uk/rear-pro...2525-c.asp
Post #623796 15th Feb 2022 4:06pm
dhallworth
Ahh yea, that's on the list of things I've already replaced on mine. Laughing 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #623798 15th Feb 2022 4:07pm
