Home > Technical (L322) > Restricted performance P004B and P004C on 4.4tdv8
Warminster 201289
Hi,
I have recently replaced the pulley tensioner and idlers and whilst it was apart thought I’d do the oil cooler gasket and o-rings. Since then whenever I take the car for a run and go to accelerate hard, as the second turbo would kick in the car goes into limp mode. I replaced all the boost hoses as thought this may be the issue but it is still present. The csov can be moved by hand so I assume it is working. However after clearing all codes and then driving, the car goes into restricted performance and the codes p004b and p004c are present. If I drive carefully to avoid higher revs the issue won’t occur. I am now at a loss to what could be causing this.
Thanks in advance.
Post #623299 11th Feb 2022 4:26pm
Dolphinboy
boost control solenoid/sensor?
Post #623311 11th Feb 2022 5:11pm
Baltic Blue
https://www.fullfatrr.com/forum/topic60579.html
It was a different fault code but referred to as boost air control solenoid.
Just to the left of the CSOV, the plug was hanging out on mine and all cleared when I managed to push it home.
PS
I got to it from the top by removing the throttle body hose and forcing my arm down the gap behind the radiator.
Post #623316 11th Feb 2022 5:29pm
Warminster 201289
Thanks for the responses.
I did check that the wire was connected earlier by removing the throttle body hose as though/hoped it may of been something as simple as that but unfortunately not.
Maybe it is an issue with the sensor. Is there any way to diagnose this?
Post #623323 11th Feb 2022 5:55pm
DrRob
The Workshop Manual in the Wiki has a section on Diagnostic Trouble Codes.
Might be worth checking in there for those codes Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #623381 12th Feb 2022 8:38am
