Home > Technical (L322) > 2006 - switched live and permanent cables behind clock
Superspoons
Hi,
I'm Wiring in a blue tooth kit and need ignition live & constant live cables. Does anyone know what colour the respective cables are - the ones I'm hoping to break into are on the passenger side foot well behind the analogue clock coming down from the dash to centre console.
On my 2003 4.4 there was a red/green stripe. I can see a red/green stripe on my 2006 (constant live) - but not a purple/white stripe (ignition live) which the 2003 had.... Gavin
Post #62293 1st May 2011 2:14pm
if you have a ciggy outlet in the armrest cubby then take the power from there...btw your little car icon needs updating.. ... - .- -.
Post #62294 1st May 2011 2:50pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
in the range rover the cigar sockets are only live until the car goes to sleep then the power to these outlets is cut off, so they are not live all the time, best bet is to run a wire from one of the main fuse links or directly from the battery if you cant find one.
Matt
Post #62306 1st May 2011 4:36pm
its for bluetooth matt, surely you dont want that active all the time which will result in a flat battery.. ... - .- -.
Post #62308 1st May 2011 4:40pm
mattstevenson2005
you and eye know that Whistle but the request was for both a always live and ignition wire
matt
Post #62312 1st May 2011 4:46pm
