Air Con - help with diagnosis pls | |
Did an approximately 2300km trip this weekend, its summer here so temperatures during the day are high, on this trip highest noticed outside temp clocked 38oC. Id say the average was around 34oC.
Day 1 no problems.
Day 2 problems! Approx 3 hours into the drive the air flow from the vents all but stopped. Turning up the fan speed there is a real and audible increase in noise indicating there must be increased air flow behind the dash, but not really coming through the vents. Stopped in the nearest town, didnt notice anything on the outside, switched car off and got a snack from the shop, restart and all is ok again only for about another hour later for it to happen again. This second time more flow through the vents, but not nearly as much as expected/needed so turned it up to full (which made things bearable) - pushed on and arrived safely home.
Note
...that at all times ice cold air conditioned air was coming out of the vents, it was just not really blowing through the vents.
...also havent sorted this issue yet, related? https://www.fullfatrr.com/forum/topic61207.html
Final stage resistor and/or blower motor?
...not so sure, when turning up the fan speed there was a noise increase indicating to me it must be doing its job.
Thoughts? 2011 Vogue SE 4.4 TDV8
