Home > Maintenance & Mods (L322) > L322 2005 4.4 m62 Coolant trouble?
Sigmundreder
Norway 2005 Range Rover Vogue 4.4 V8 Buckingham Blue
But wouldnt it with an airlock Get to hot?
I have never experienced that its wont reach normal temp.
Post #622612 5th Feb 2022 6:49pm
Sigmundreder
So the car is now at a local garage in Oslo, which have used many times before.
The mechanic called me yesterday.
They have tried all the tricks, inlc. vacum.
Still no heat...
Hopefully they will at least figure out what the problem is.
Will report back as soon as i know more.
Post #623131 10th Feb 2022 7:25am
Sigmundreder
Aux coolant pump will be replaced. That should do the trick Smile
Post #623290 11th Feb 2022 1:30pm
Gsxr1250dave
I'm not sure how we missed this 1 for you, that pump is a common failure for no cabin heat
Post #623591 13th Feb 2022 5:25pm
Sigmundreder
No worries Smile
But i think the whole thing is a bit wierd, since everything worked OK until the main waterpump went bad.
Maybe just a coincedence that both failed at the same time..
Anyways, we are now waiting for aux waterpump to arrive.
Hopefully that will sort everything out. Maybe that also will get me one step further to get the webasto to function as well
Post #623670 14th Feb 2022 12:52pm
Sigmundreder
Picked up the car today.
With the new aux water pump, everything is back to normal.
So that had also failed.
Post #625029 28th Feb 2022 6:45pm
Gsxr1250dave
Well done I'm sure your glad to be having heat in the car after all this time
Post #625032 28th Feb 2022 7:20pm
Sigmundreder
Haha! You bet! Its been freakin freezing here Smile
Next job will be spark plugs.
And then i would love to get the FBH going.
Post #625033 28th Feb 2022 7:22pm
